Filter by Custom Parameters
767
02-20-2026 08:25 AM
MeleKoneya
I have a living atlas layer that I would like to filter by the bounding box for the state of Arizona.
I understand that I can do this with Custom Parameters in the map viewer.
Can someone provide some guidance as to what parameters are needed and the format for them?
Thank you,
Mele
Katie_Clark
MVP Regular Contributor
You can define custom parameters for a layer in the settings of the web map:
Documentation for the types of parameters accepted can be found here:
https://developers.arcgis.com/rest/services-reference/enterprise/query-feature-service-layer/#reques...
In my screenshot example, I used inSR = 4326, and geometry=-114.8165,31.3322,-109.0452,37.0043
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
MeleKoneya
@Katie_Clark
Thank you for including this:
I was not having much luck find a good example.
DebapriyaPaul
Hi @MeleKoneya , to filter by a specific state name, the custom parameter in Map Viewer could look similar to the following example,
custom.pngNote: Use the Fields panel in Map Viewer to confirm the Field name that contains State Name information.
