Filter a layer using a dynamic relative-value
1947
09-16-2024 09:03 AM
RobertoRossi
In a map I’m using a dynamic layer (WFS) which updates daily, containing rain gauge data.
I would like to filter the layer (using the rain amount numeric filed) in order to show only the highest precipitation value feature. When I try to filter the layer using the numeric field I just find only absolute filter expressions:
which apply to a particular value.
Is there a workaround to filter by the greatest value (like Relative-date filters do)?
Roberto
KimOllivier
Honored Contributor
I appears that the field item is not recognised as numeric. I am also wrestling with WFS feeds being read only and intermittent. My idea is to copy the WFS feed to a real Feature Layer daily that you have full control over the schema and also filters. This is easy from Pro, but not ideal and not automated. So maybe a AGOL Notebook with a Task to refresh each night?
I found Arcade is disabled for WFS layers so that is not an option.
RobertoRossi
Thank you @KimOllivier , In one version of my Map I already designed a join from a Feature Layer from CSV to a Feature Layer using Data Pipelines: this is the Output Feature Layer: https://arcg.is/eX1qO
The problem is that it seem impossible to filter the layer using the maximum value of numeric field.
Maybe it is possible a workaround using Arcade configuring an expression in styles (or even labels), but I need some help with Arcade...
KimOllivier
Honored Contributor
"Not all Arcade functions are suitable for every profile. For example, profiles that execute expressions for all features in a layer (e.g. visualization and labeling) don't allow expressions to access data via FeatureSet functions."
I don't think you are allowed to use Arcade in a map filter because of the overhead implied. You will have to process the highest value earlier before the data is in a MapView.
RobertoRossi
:@KimOllivier , you are right, Arcade is not available in map filters: that's way  I was wondering there could be a workaround via styles or labelling...
KimOllivier
Honored Contributor
The only way I have done this is by using the Python API and Pandas to find the maximum value and then update a field
