Field Maps Error Code 3057
3923
09-23-2022 01:53 PM
ChrisstianSandoval28
Hey guys I am working on the Field Maps app and one of my layers keeps giving me the same error below. When I check ArcGIS Online the layer works but not in the app. Any Idea what it could be causing the problem?
Map:
CT
Layer:
Name of my Layer
Domain:
ARCGIS_RUNTIME
Code:
3057
Description:
Geodatabase reserved name.
2 Solutions
ChristopherCounsell
MVP Frequent Contributor
The error code is indicating that a field name is a reserved keyword. Some words like 'DATE', 'DELETE' or 'TRUNCATE' should not be used as field names as they are incompatible with databases. There is a strong chance that you have such a keyword in your layer.
ArcGIS Online would have a different underlying database to ArcGIS Field Maps. Some keyword restrictions would only manifest in one or the other, not both. General best practice is to avoid a list of keywords to ensure you don't have issues when data is moved around e.g. to a SQL server, file geodatabase, shapefile...
Take a look through your fields. Here are a couple of lists that may help:
https://support.esri.com/en/technical-article/000010906
https://pro.arcgis.com/en/pro-app/2.8/tool-reference/tool-errors-and-warnings/010001-020000/tool-err...
Please don't forget the kudos 🙂
I actually re-created the layer using ArcGIS Online. Once I put it on the Fields Maps App I no longer got the error message.
ChristopherCounsell
ChristopherCounsell
Thanks for the update. I suspect something was off with the original layer - possible the field name or a data corruption. Would need to know more about the data formatting and how it was originally created. If the issue persists or reoccurs feel free to share.
JMCM
I realize this topic is old, but posting for future users who Google this error code like I did.
In my case, I got error 3057 because Field Maps (desktop Map Viewer was fine with this) did not like field names where there were more than 2 consecutive underscores. This was a case of translation from Excel fields, e.g. "Example (% Test)" would be translated to "Example____Test_" due to special characters.
Hope this solution helps someone else.
