Field is grayed out when adding or editing a record in Web map
574
10-20-2022 11:06 AM
AlexManikas
I am having an issue where I can not edit values within a web map or fill out the field when adding a new record on the layer. It simply shows that it is greyed out. The layer the field is in is set to "editable" attribute and geometry, I am the owner and I have the actual field set to editable within the Data tab of the layer. Greyed out fieldGreyed out fieldfield set to editablefield set to editablelayer field is within is set to editablelayer field is within is set to editable
