Feature layer is visible in Portal but not in ArcGIS Online
980
08-25-2021 09:04 AM
BradyWalker2
This is my first time working with Portal so please excuse me.
I have published a feature layer through our ArcGIS Server with feature access enabled. I can view and edit the feature layer in Portal. However, if I add the REST URL in ArcGIS Online it recognizes the layer, but does not display the feature and the attribute table is empty. I have sharing in Portal set to Everyone.
What am I doing wrong?
MichaelVolz
Esteemed Contributor
Have you checked both Server Manager and Portaladmin logs for errors?
Do the AGS services have access outside your firewall to AGOL?
BradyWalker2
Our services do have access outside our firewall. We have several map image layers served out on this machine that go into ArcGIS Explorer maps. We have not had problems with those.
I was able to find these generic errors in arcgis server after I enabled feature access.
MichaelVolz
Do the time stamps on those errors "Method failed... The parameter is incorrect" coincide times when you were trying to access the feature layer in AGOL?
What version of Enterprise are you running (e.g. 10.8.x, 10.7.x, etc.)?
