Error: Unable to open the map because the basemap is not available.
1359
11-23-2021 06:51 AM
TylerT
Greetings,
I'm getting this error in AGOL with any basemap I select.  Where are can the Administrator's basemap configurations be found?  I am the administrator and just need specific location of the setting.   Or, is there a deeper issue that somebody else has experienced.
Thank you,
Tyler
TylerT
Well, mystery solved.  ESRI blocked my IP.  Issue resolved!
Thank you.
Robert_LeClair
Esri Notable Contributor
In researching this error message, I found a few things:
  1. Was there a recent implementation of security software in your org?  If so, you would need to implement an exception to allow ArcGIS Online certificate as the default basemap coming from ArcGIS Online.
  2. Was a user role created?  Does it allow the users to view content shared through the org's groups?
Hope this helps!
TylerT
Thank you.
