Error: Geodatabase Data Type Mismatch when trying to submit related record in Esri Field Maps
3975
08-30-2022 06:03 AM
GISUSER6
Hello, I have two related tables related to my water hydrant feature class. So two relationship classes to the hydrant and the tables are hydrant inspections and flushing. When I upload the data to arcgis online and try to submit a related record form to the table in Field Maps, it tells me "Geodatabase dara type mismatch". I cannot figure out what is going on. Anyone have any ideas? Attached is a screenshot of the error I got when trying to test out the tables.
GISUSER6
Yes. The problem was that the field that I was using to relate the table to the feature service was a different data type in the table vs. the feature class.
Flush ID Field in Hydrant Feature Class: Double
Flsuh ID Field in Hydrant Inspection Table: Text
So one had to be changed so that they both had the same data type.
TravisAndersonPE
Anna,
Did you ever figure out what was causing your error? I am getting the same error when trying to submit new point in a feature layer. I can edit existing points and submit, but can not add new points to the layer.
TravisAnderson
GISUSER6
