I have an AGOL Hosted Feature Service that's been around for a long time. Several maps and apps have been built on the feature service.
Today, i deleted one field from the service (field name = 'HearingDate'). To delete the field, I used the AGOL Item > Data > Table page; clicked the field name, then selected Delete. The field seemed to be deleted as expected:
After dropping the field, i am unable to edit data in the table:
All those efforts result in the following response:
{"addResults":[],"updateResults":[{"objectId":51099,"uniqueId":51099,"globalId":null,"success":false,"error":{"code":1000,"description":"Invalid column name 'HearingDate'."}}],"deleteResults":[]}
Any ideas about what's going on?
Here is a typical update request against the feature service. Note that the phrase 'HearingDate' is not part of the request.
[{"attributes":{"OBJECTID":51099,"CaseNumber":"6705943754","DateReceived":1532735978738,"Complainant":"test 105","ComplainantPhone":null,"ComplainantEmail":null,"Address":"Test Address","City":"Test city","IncidentDescription":"testing","SiteStatusDate":1532735978738,"DispositionDate":1532735978738,"DispositionNotes":null,"TagNumber":null,"TagIssuedDate":null,"IgaPartner":null,"Icomp":null,"PostingDate":null,"Latitude":null,"Longitude":null,"CitationNumber":null,"RespondentName":null,"IssuedDate":null,"ResponseDate":null,"Costs":null,"TotalCitationAmount":null,"JudgementDate":null,"HearingsOfficerJudgement":null,"CitationComments":null,"AsbestosSampleDate":null,"AsbestosSampleCount":null,"CaseAgeInDays":621,"DataApprovedDate":null,"SiteStatus":"Dirty","CleanupTime":null,"HasEvidence":"No","Disposition":"Open","CaseType":"Report","WasteSource":null,"DumpLocation":null,"EnvironmentalSensitivity":null,"DumpSize":null,"IsFreeBox":null,"CampersPresent":null,"PersonalProperty":null,"IsActive":"Yes","SuspectAsbestos":"No","ReportedMethod":"Website","County":"testing","AssignedCrew":null,"InvestigatingOfficer":null,"CitationResponse":null,"AsbestosSampleResults":null,"DataApproved":null,"SiteNotes":null,"IsTheftOfService":"No","LocationDetails":null,"ReferredToAgency":null,"ReportID":"RPT0Test","ReportStatus":"Received","ReportStatusDate":1532735978738,"ReportStatusNotes":null,"ReportedCount":1,"ReporterHasEvidence":"No","ReporterFirstContactedDate":null,"ReporterContactNotes":null,"reporterEvidenceDetails":"","EditDate_1":1534591020000}}]
Josh from Esri tech support gave me the solution to problem. I needed to disable/save/enable/save all the 'Editing' settings for the hosted feature layer. From Josh:
The editing setting "Keep track of created and updated features " creates a back end table that lists out all of the fields in the feature layer. When deleting fields, this table does not always update. When the table in the feature layer and this back end table do not match, it disallows editing capabilities. Turning this option on and off causes the table to refresh and update with the correct data.
This worked for me. Thanks for sharing!
This also solved my issue, thank you for sharing!
I am experiencing a similar issue, after doing the following:
1. Loading a hosted feature layer in to ArcGIS Pro
2. Deleting unused fields via the attribute table in ArcGIS Pro
3. Trying to carry out editing / use Calculate Field on other fields. I get the following error in ArcGIS Pro:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds.General function failure [Error code: 1000. Description: Invalid column name 'Column2'.Invalid column name 'F39'.Invalid column name 'F2016_cond'.Invalid column name 'F41'.. ]Failed to execute (CalculateField).Failed at 05 May 2023 15:49:51 (Elapsed Time: 2.10 seconds)
I have tried the suggested fix of disabling, saving, re-enabling and saving the following settings in the AGOL hosted feature layer, but to no avail. I have also tried removing and re-adding the layer to the ArcGIS Pro project in between these steps, and also closing and reopening the project. Still no luck.
I rebuilt the feature template using the Map Classic (why isn't this available in the new map yet, it's August 2023??) but that didn't work. I tried turning on/off the "Keep track of changes to the data (add, update, delete features)." but it didn't fix the problem. I then tried turning off/on all of those features (Enable editing, Keep track of changes..., Keep track of who... Enable Sync... ). I also rebuilt the Spatial Index (not sure if necessary).
Then it finally started working again.
Hi there! I followed your advice because the previous solution didn't work for me either. I wanted to thank you and share what I did in case someone else encounters the same issue.
Here's a bit of background: I have a hosted feature layer in ArcGIS Online consisting of point locations for mine sites. This layer had a lot of fields, and I decided to clean it up by deleting many of them. I deleted the fields using the "Data" tab in ArcGIS Online, selecting the fields and deleting them from there, rather than doing it in ArcGIS Pro. Over time, I've found that managing layers hosted in ArcGIS Online works better for me using ArcGIS Online commands instead of ArcGIS Pro commands—if that makes sense. Things just seem to stick better that way.
So, back to my story. I followed Mr. Alex's suggestion and adjusted the settings as shown in the image. I’m not sure if that alone fixed the issue, but what I did next definitely helped. I opened the layer in an ArcGIS Online map, went to a point, and updated an attribute. It allowed me to save the change. Then, I was able to load the layer into ArcGIS Pro and save any changes I made.
I wanted to share this extra bit of information for anyone who might come across this post. I hope it helps!
