Error downloading map in collector with join feature
996
01-13-2020 03:57 PM
AnooshehTarassoly
I am getting a sync issue when I try to download a map in collector that has a joined feature in it.
I created the joined feature using the analysis tool on ArcGIS Online between a feature and it's related table.
Here is the error I am getting:
Domain: com.esri.arcgis.runtime.error
Code: 1002
Description: invalid uuid string
Ultimately I am trying to symbolize a layer based on data in a related table. We have records of inspections and I want the symbology to changed based on the latest status of the most recent inspection.
by Anonymous User
Not applicable
Hi Anoosheh Tarassoly‌,
If you are saving the join as a hosted feature layer view, from the documentation this cannot be taken offline:
If you want to symbolize based on related data, use the Join Features tool to associate the field you want to symbolize on from your related record with the feature, save the result as a new hosted layer view (it updates as the original data changes), and use that hosted layer view in your map. See Join Features in ArcGIS Online or Join Features in ArcGIS Enterprise. Hosted layer views created with the Join Features tool are read-only and can't be taken offline
Hope this helps,
-Peter
