Enable search source in Web Map no longer option in Settings
1102
08-05-2024 05:56 AM
Tiff
There is no longer a section in the "Settings" tab of the map item that allows you to set search source based on layers. Luckily in maps that used to have search sources set, the search still works. However, where did the configuration go? Is this something that disappeared with the new update? Please advise, thank you!
RussRoberts
Esri Notable Contributor
I am still seeing it in new maps.  Can you share a map you are seeing this issue? Is it a map you are the owner of or are you an admin in your organization?
RussRoberts
Tiff
Hi @RussRoberts - thanks for confirming! Strange, but I am seeing the setting back now. We are having some issues with Portal services and maybe that was the reason why. I do not have a screenshot but before, I was only able to see the "Use in ArcGIS Collector" and "Use in ArcGIS Field Maps" checkboxes.
