Embedded map not showing
802
09-02-2025 01:31 AM
ALICIACARBALLALTOIRAN
Hello, I have a web map embedded in our department website. Last week it was working as expected, but now is showing a blank page and we haven't changed anything. Is there any kind of change in arcgis online affecting emeddded maps?
Thank you!.
Laura
by MVP Regular Contributor
I faced an issue similar where something within the website changed. I just removed and re-added and has been working fine since.
DanielFox1
Hi @ALICIACARBALLALTOIRAN
How is the web map shared, try changing the sharing level to public and check if this works?
You may need your site to allow arcgis online to come through?
I hope this helps in some way.
Hi, the web map sharing level is public. And the site is allowing to arcgis online to come trough. Everything worked perfect untill this week.
JonathanMcD
Laura
