Editing issues with Quick Capture
275
07-31-2025 06:04 AM
Katie_Scheip
Good day!
I have a question regarding in issue I am having adding a feature to Quick Capture. (My ultimate goal is for a non-ESRI login user to be able to update a layer with pertinate information, so if there is a simpler way to do this, I am all ears.) I am trying to use Quick Capture as outlined by this video. I am trying to create a disaster welfare check system in which a resident of my county would fill out a Survey 123 so they could request a welfare check for a resident of our county. I am creating a Quick Capture survey for the County employee to fill out describing the outcome of the welfare check. I am using a joined view of these two layers as described in the video. My issue is that I keep getting errors when I try to use my joined layer in Quick View.
I click on the joined view layer and see this in settings...
I think click on the root layer to change editing, but every editing option is turned on.
Does anyone have any insight on what is happening here? Thank you!
Best,
katie
ChristopherCounsell
MVP Frequent Contributor
You can't enable editing on joined view layers
https://doc.arcgis.com/en/arcgis-online/manage-data/manage-editing-hfl.htm
You may also encounter issues with sharing data for public collection. There may be ArcGIS Online administration settings you need to enable.
I believe you also need a hub premium if you want to use quick capture for public users:
https://doc.arcgis.com/en/quickcapture/faq/faq-prepare.htm
It's more common to use Survey123 for these scenarios:
  • Survey form can be browser (not app) based
  • Survey form can be launched from a map or URL to pass values
  • Configuring a view for public data collection (adds only, no queries) is secure
  • Repeats and related tables can be used to track visits;
  • Default values and backend processing can be used to curate submissions and update parent layers
Cheers
Chris
