Editing 'disabled' - even though editing is enabled
4118
10
11-01-2023 04:00 AM
Kimbers
Hi all,
I have a layer that I cannot add to the Edit widget in Experience Builder. When I look at the hosted view layer in the map, it tells me that editing is disabled, however I do have editing enabled on the layer. I'm using ArcGIS Online
Map:
Layer:
Can anyone help?
Thanks
bbollin
Hi @Kimbers is the feature layer public/does it have public data collection enabled? I also noticed this
Is this layer related to another hosted feature layer by chance
Kimbers
Thanks @bbollin
Yes it's a View layer. Neither the view nor the original layer have public data collection enabled
Thanks
bbollin
@KimbersI'm assuming that the original layer has all the correct editing settings as well? If so, I would suggest opening a support bug so we can take a closer look
https://support.esri.com/en-us/contact/report-bug
Kimbers
Hi @bbollin
No, the original layer is non-editable. I didn't think that this would make a difference?
bbollin
is it possible for you to share the service?
CMV_Erik
I'm also having this problem that started after the latest AGOL update. A layer that was working fine became un-editable. I used a view to replicate the same data and form, set it up in Experience, and it was working fine. I went back in a few days later, and it too was no longer editable.
bbollin
@CMV_Erikis your setup the same as described above? A view layer with editing and the parent without editing enabled?
CMV_Erik
They are both views of the same parent feature layer, but I have explicit permissions to edit the parent (editing is enabled, and I am a member of a group listed under "Who can edit features?")
bbollin
@CMV_Erik are you able to share the service?
