Edit hosted feature layer from ArcGIS online in ArcGIS Pro
1792
03-14-2019 09:24 AM
AlisonCorey
I've published a hosted feature service to ArcGIS Online which is editable. When I open the same hosted feature layer in ArcGIS Pro as a web map layer through the REST services the layer doesn't draw but the Create Feature option available. If I add the map layer through a ArcGIS server connection the layer is visible but not editable. I get "Layer is not editable, unknown error".
I'm hoping there is an quick solution for this.
Alison
MarisaClaggett
Hi Alison,
Have you logged into your AGOL account in the top right corner of Pro?  Is this a Server or AGOL hosted feature layer?
If you log into your AGOL account, you can then pull in the hosted layer from the Catalog > Portal tab.  What version of Pro do you have by the way?
Best of luck,
Marisa
AlisonCorey
Hi Marisa,
I'm running version 2.3.1. It is a server hosted feature layer. ESRI support has been working on this issue for over a month. When and If we upgrade the issue could be solved but we are not ready to upgrade.
Thanks for the suggeston
Alison
KellyGerrow
Esri Alum
Which editing settings are enabled on the hosted feature service?
