download the county-level data
1251
03-01-2023 08:45 AM
FarzanKarimi-Malekabadi
How can I download the county-level data of a desired map?
BrianBaldwin
What map/what data?
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
thanks for the response!
2020 recycling habits USA
BrianBaldwin
In ArcGIS Online - you could 'enrich' a dataset with this data using Map Viewer - there are a wide-array of variables related to recycling patterns.
Your general workflow would be:
1) Get the geography level data that you need (US Counties/Zip/etc.) - this could be pulled from ArcGIS Online or from the US Census Tiger data.
2) Add your data to MapViewer - then use the Analysis tools and the Enrich tool to select the variables you need/want.
If this is all brand new to you - you could easily 'google' any of the above steps and get some detailed documentation.
