Doubt with webmap styles 2 string variables
2217
02-25-2021 06:55 PM
PlaninforAdmin
Hello community,
I have a webmap with a layer and I need to occupy 2 fields to create the style I need, for example:
Type_field: values (type1, type2, type3)
Active_field: values (YES, NO)
I have the option to add a second field, but the second field can only be of the numeric type, it cannot be of string.
From the beginning I defined it that way.
Is there a way to change this?
or maybe it is possible to create an expression that returns a value?
Try creating an expression like this: Concatenate (DomainName ($ feature, "PLAN_TYPE"), '/', DomainName ($ feature, "ACTIVE"))
but it returns a message saying, "Warning
The expression must return a numeric value "
XanderBakker
Esri Esteemed Contributor
Hi @PlaninforAdmin ,
It would be best to change the structure of your data since it does not align with what you want to obtain. You can however keep a numeric field and create a domain for it to have an understandable description of the composed value. If you want to symbolize the two fields you don't have to create a new field, you can use Arcade and concatenate the values.
If however, you want to create a unique numeric value, it might be an idea to get a structured result. Have a look at the expression below:
var active = DomainName($feature, "ACTIVE");
var plan = DomainName($feature, "PLAN_TYPE");
var dct_active = {"YES": 1, "NO": 2};
var dct_plan = {"type1": 1, "type2": 2, "type3": 3};
var result = 0;
if (HasKey(dct_active, active)) {
    result = dct_active[active] * 10;
} else {
    result = -1 * 10;
if (HasKey(dct_plan, plan)) {
    result += dct_plan[plan];
} else {
    result += -1;
return result;
A value of 13 would represent: ACTIVE Yes and PLAN_TYPE type3...
XanderBakker
var result = 0;
} else {
    result = -1 * 10;
} else {
    result += -1;
return result;
PlaninforAdmin
Muchas gracias. 😃 solucionado.
