Domains in Arcade
14835
14
08-11-2020 12:45 PM
NWEdisonTeam
Hi
I am trying to parse out a conditional expression for visually displaying locations in Arcade (Arcgis Online) that contains two domains and I am either A, not getting the resultant I want, or B getting an error, depending on how I structure it.
 if (DomainName($feature,"WA") == 8/10/2020 - 8/16/2020 && DomainName($feature,"InSta") == 'To Be Installed') {Return 'Needs to Be Installed'}
This version returns null values. Any help would be appreciated!
Tags (1)
KenBuja
MVP Esteemed Contributor
No, they are interchangeable. Notice I had to use double quotes in the else return since the string contained a single quote.
Something like this works fine (from the Playground), but you try to be consistent
iif($feature.LASTEDITOR == "Esri", 'Yes', "No")‍‍
NWEdisonTeam
To Continue this, I am finding that the expanded code is not yielding the corresponding results. Any thoughts?
if (DomainName($feature,'InSta') == 'To Be Installed'){
if (DomainName($feature,'WA') == '8/10/2020 - 8/16/2020'){
return 'Priority 1 Install';
} else if (DomainName($feature,'WA') == '8/10/2020 - 8/16/2020'){
return 'Priority 2 Install';
} else if (DomainName($feature,'WA') == '8/24/2020 - 8/30/2020'){
return 'Priority 3 Install';
} else if (DomainName($feature,'WA') == '5/25/2020 - 5/31/2020'){
return 'Do Not Install'
} else {
return 'Installed';
KenBuja
One thing I notice is your first two date range if statements use the same range. What are you getting and what are you expecting? It is possible to see a snapshot of the data?
NWEdisonTeam
1. That code was wrong I mis-copied so apologies
2. I got it to work by changing the structure and just doing a bunch of else if clauses. See the screen shots below:
I was overly complicating it
AdamBakiera
I am having a similar issue. Here is my code:
var days = DateDiff(Now(), $feature["Inspected_Date"], "days");
if (days > 60 && days < 180 && $feature["Inspection_Status"] == 'Repair Needed') {
return "This was inspected between 2 and 6 months ago - Repair Needed";
if (days > 180 && $feature["Inspection_Status"] == 'Repair Needed') {
return "This was inspected more than 6 months ago - Repair Needed";
if (days < 60 && $feature["Inspection_Status"] == 'Repair Needed') {
return "This was inspected in the past 2 months - Repair Needed";
if (days > 60 && days < 180 && $feature["Inspection_Status"] == 'Passed') {
return "This was inspected between 2 and 6 months ago - Passed";
if (days > 180 && $feature["Inspection_Status"] == 'Passed') {
return "This was inspected more than 6 months ago - Passed";
if (days < 60 && $feature["Inspection_Status"] == 'Passed') {
return "This was inspected in the past 2 months - Passed";
I know for a fact the days variable and that logic works because that's the way our application is set up right now. We are just wanting to add that inspection status element.
