Display date field in Popup with MM/YYYY format in WebMap
1565
05-16-2022 12:50 PM
JoseSanchez
**bleep** oeveryone,
Is there a way to format  a date filed in a Popup  window in a WebMap?
I would like to display only month and year  (MM/YYYY)
Thanks
SteveCole
Honored Contributor
You could use an Arcade Expresison to do that work. Example:
var theDate = Now();
var theMonth = Month(theDate) + 1; //Month() returns a value 0-11 so add 1 to it
return theMonth + '/' + Year(theDate);
KenBuja
MVP Esteemed Contributor
A simpler way would be to use Text formatting
var date = Now();
return Text(date,"MM/YYYY");
RhettZufelt
MVP Notable Contributor
If you want just name of the month and year ( May 2022 ), that is built in to the popup configuration in the Classic map viewer, and the fields tab in the new map viewer.
R_
JoseSanchez
Thank you.
How do I check for null values in arcade?
RhettZufelt
