Dashed Symbology
3635
10-20-2015 07:38 AM
JeffGarcia1
Hey just getting started in developing ArcGIS online maps\apps. I having a problem with symbology. In my mxd  I have lines symbolized as dashes by a unique field which gives me roughly 90 symbols. In my mxd it is set correctly but when I publish the map to my server and consume the service the symbol is set to a solid line in 90 percent of the features. Looking at the rest endpoint is does come across as solid instead of dashed but again there are 10 percent that come over correctly. Don't know where the mix up is, any help is appreciated.
RickeyFight
Jeff,
Can you provide some screen shots of what you are seeing?
JeffGarcia1
JeffGarcia1
Screen shots show the mxd symbology and then the rest endpoints. My features aren't coming over with the symbology set in mxd correctly.
