Dashboard use of FeatureSetByPortalItem
4543
12
02-08-2023 07:28 AM
PSGeo
Dear all,
I am trying to do a dashboard in AGOL. Using the example 2 of this link:
However, to work I have to do something that I really don't know.
I need to to clean the "name" from unnecessary code, using this:
Trim(Split(DomainName($feature, 'name'), '_')[-1])
However, it does not accept global variables... therefore $feature - does not work. so after some changes
I end up with this:
var fs = FeatureSetByPortalItem(Portal('https://xxxxx.maps.arcgis.com'), 'a73a2a04e8b24aa7a5a514193a3057a0', 0, [Trim(Split( 'name', '_')[-1]),'DELIV_DATE','sqKm'], false);
But I have no idea how this can work for the remaining code of that link.
Can someone suggest me some fixing.
cheers
PS
PSGeo
date is done, thanks!!!
The filter is not. How do I put the :
var fs = Filter(
    FeatureSetByPortalItem(...),
    "local_type = 'some value'"
into this?
    0,
    ['name','DELIV_DATE','sqKm'],
    false
cheers
Pedro
jcarlson
MVP Alum
You're not putting it into it, you're wrapping the filter around the existing expression.
var fs = Filter(
        0,
        false
- Josh Carlson
Kendall County GIS
PSGeo
Hi still in the same example:
how do I incorporate from the example of the page this: "return GroupBy(fs, ['COUNTY'],   "
I tried this... but error:
return GroupBy (FeatureSet(Text(out_dict)), ['clean_name'])
cheers
Pedro
