Custom Projections in AGOL
3121
5
01-04-2021 12:19 PM
AnnaScholl
Dear friends,
It seems this has been asked before but the answers didn't quite give me the info I'm looking for. I have a custom projection for India (transverse mercator) for a school project in Pro. We are now making a dashboard and need to transition to AGOL. Web Mercator is, of course, completely inappropriate for most maps, and I need to change the projection. The question is, how? All of our data is in this custom projection, so this shouldn't be a problem. If the answer involves Arcgis REST, how do I go about publishing my own service?
Many thanks,
L
AnnaScholl
by Anonymous User
Not applicable
Hi Lydia, check out the "How to Make Non-Mercator Web Maps" section in the following article: https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/here-are-some-equal-area-projected-m...
Hopefully this helps!
AnnaScholl
This would be great, and seems straightforward, but I can't figure out how he starts out... "choose a projection that suits you." This I have, but how did he get the landmass data, water data, etc? Where could I find this?
by Anonymous User
Not applicable
Hi Lydia,
In addition to Cartochien's advice, if you still have ArcGIS Pro you can change the projection using these steps:
  • you can then you can publish the layer to AGOL
  •  Open the map in AGOL through your contents
  •  share as a web app
  • choose the dashboard option
Hope this helps
AnnaScholl
Thanks! Unfortunately, when I go to publish the layer to AGOL, it gives me an error that the basemap (e.g. Topographic) is in a different projection than the other layers (my custom projection). I haven't been able to figure out how to get through this step.
L
AnnaScholl
