Custom Label Arcade multiple conditions
760
07-21-2022 08:30 AM
KWilliams
Hello - I am attempting to write what should be simple arcade code, but I just don't have the experience. I know how I'd write it in Python, but Arcade is throwing me.
My first two statements work fine. But I need an option for when these two fields are BOTH == 'Yes', the code returns 'OHG Slack Span'. Any help will be greatly appreciated!
if ($feature["Overhead_Guy"] == 'Yes'){
return 'OHG'
if ($feature["Slack_Span"] == 'Yes'){
return 'Slack Span'
I found a technical support page Use multiple conditions that makes the answer seem obvious but putting the || between my conditions is throwing the 'unexpected token ||' error
Thanks!
KenBuja
MVP Esteemed Contributor
Don't use a return in each of the if statements, but use a variable. Putting a space after the OHG in the first statement makes it ready for the next statement, but it will get trimmed away if not needed in the return.
var output = '';
 output = 'OHG ';
  output += 'Slack Span'
return Trim(output);
KenBuja
var output = '';
 output = 'OHG ';
KWilliams
That worked first try! Thank you so much!
KenBuja
Glad to help. Don't forget to click the "Accept as Solution" button
