ArcGIS Mapviewer Change default name of points in edit selection
353
07-21-2022 01:01 PM
Labels (2)
Caitlin
Hi all,
I'm working on a map where I have to edit several points, an issue I'm running into is that when I have multiple points in the same area, the display name in the edit section for multiple features is not the unique field. Because of this, I have to click through each feature in order to find the one I want to edit. I've attached a screenshot that will hopefully explain my issue more clearly.
Is there a way to change the field that is displayed here from the field that contains 'world' to the field that contains the business name?
