Creating a join with another join: Unable to save as hosted feature layer view
1379
03-31-2019 06:39 PM
JasonBatory1
I create my first join and check "Create results as hosted feature layer view".
Then when I join this new feature layer view to another layer the option to "Create results as hosted feature layer view" is greyed out.
I've tested using a "normal" feature layer view and when I join that to another layer I can save it as a hosted layer view.
So why can't I create a hosted feature layer view in my first scenario?
I have a feature layer with the following relationships: parent -> child -> grandchild
and I want to join all three of these tables into a "live" view.
Is this even possible?
KellyGerrow
Esri Alum
Do you own all of the layers?
Please note these limitations when storing join results as a feature layer view:'
You can create a hosted feature layer view from the analysis results if all of the following conditions are met:
  • You are the owner of both layers.
  • Both layers are hosted feature layers.
  • You are performing an attribute join.
https://doc.arcgis.com/en/arcgis-online/analyze/join-features.htm#ESRI_SECTION1_EA1638CEB036429B86D3...
JasonBatory1
Thanks Kelly,
I do own all the layers and I'm performing an attribute join.
