Create an online feature layer template
1352
12-17-2018 05:45 AM
JoeNunn
Is it possible to create one of the templates that appear in the Create button in contents here?
Thanks
Joe
XanderBakker
Esri Esteemed Contributor
Did you try to follow the steps explained here? Manage feature templates—ArcGIS Online Help | ArcGIS
JoeNunn
I saw that but i didn't see it referring to the list of templates in the screenshot i had above.  I will give it a go and see if a template appears there.  Thanks
JoeNunn
From what i can see Its not really what i want. I have  a hosted feature layer that is made of of 7 or 8 layers (point lines and polygons) each already with the symbology set for editing.  If i want to create a new hosted layer it is possible by just going to the "From Existing Layer"  tab and search for the layer however it would be preferable if only the layers visible were templates that are chosen.  (similar to an old mxt in arcmap)
