Create a Buffer Feature from a Point Feature in ArcGIS Online
1644
10-25-2021 05:16 AM
AliceWilson
We have a point and parcel (polygon) feature of B&B and want to create a tool online that will allow us to locate new B&B's and create a buffer around the parcels that the point resides at. It also needs to categorize the feature as partial or full use of the home. Any thoughts appreciated.
Tags (1)
ABishop
Yes, it will create a buffer as a feature.  You just have to enable it for the user.
Amanda Bishop, GISP
ABishop
Hello @AliceWilson
Using the Web App Builder application, you can use the "Near Me" widget to configure a buffer tool and choose which fields are visible in your results.
Amanda Bishop, GISP
AliceWilson
Thanks will it create that buffer as a feature as well? I'll check into it as well.
ABishop
Amanda Bishop, GISP
