Compare Analysis sync
1015
03-28-2019 02:38 AM
RenátaAradi
Hi
I have a problem with an older Compare analysis map.
Earlier the auto-sync function worked, but I had to update the maps and it doesn't function anymore. I can't just build the app again, because that would change the link and that is already shared and used.
If I load other maps to the left side, the sync function activates again, but not with that specific map I have to show there. I built up the map on the left side several times and tried to publish from ArcGIS 10.5 and Pro, but it didn't help.
Have anybody had symilar problem and found solution?
KellyHutchins
Esri Notable Contributor
This is due to the map's having incompatible spatial references.  One map is wkid:102100 and the other is wkid:25833
If both maps have the same SR then the sync should work correctly.
KellyHutchins
RenátaAradi
Fantastic Problem is solved! Thanks a lot
