Changing Hosted Feature Layer Extent
1857
10-11-2022 12:42 PM
DanielMiranda2
I have a hosted feature layer in ArcGIS Online consisting of 4 layers. One has data, the other three do not. If I add this layer to a map in ArcGIS Pro, the default extent is the entire world. I would like the default extent to match the layer that does have data.
Using the visualization tab and updating the home extent does not work. I also tried to update the extent values in the REST Directory through the Admin tab, but even though I am able to save the layer definition, the extent values do not actually change. Note, that I am updating the lastEditDate as mentioned here. Error: Unable to update feature service layer definition. Invalid definition for 'lastEditDate' (esr...
Is there no way to change the default extent stored in a hosted feature layer?
Bhargav_Reddy
Were you able to find a solution to this? I'm in a similar boat
Marc_Patti
Interested in a solution to this as well, because it's holding up an integration with a new vendor.
MollyE
@DanielMiranda2  @Marc_Patti @Bhargav_Reddy
I know this is old but I just stumbled across this post while looking for something else. Have you tried going to the settings page and clicking "Edit extent" from there, rather than the visualization tab?
