Capital Projects Dashboard : How Do I...?
2271
03-08-2018 06:39 AM
BrianO_keefe
Honored Contributor
So in the Capital Projects Dashboard there is a section that displays the project details... At the bottom of that section there is a 'table' (html) that has colored cells to highlight the project phase.
Screenshot of the Capital Projects Dashboard, Project Description block
PreDesign | Design | Construction | Closeout
I am COMPLETELY clueless how to add that in. Does anyone know?
ChrisFox
Hi Brian,
Please check out the thread below. In it I describe how to author the pop-up and configure the arcade expressions to support the pop-up:
https://community.esri.com/thread/207970-problem-with-the-capital-projects-solution-deployment-tool
I would also recommend leveraging the Solution Deployment Tool described in the getting started section of the help for the Capital Projects Dashboard solution. This will lay down the layers, webmap and dashboard in your org already configured with everything you need for the solution.
