Cannot display Dashboards in online portfolio
1323
06-05-2019 09:51 PM
JeremyHerbert
Hi There,
I have an ArcGIS web application that I use to showcase some of the ArcGIS online content that I have created. For reference here is an image:Portfolio Screenshot
and here is a link for the portfolio.
I'm not sure who created this application, but it is designed to create tile icons of ArcGIS online content that is saved to a group.
The second (top-center) icon is a Dashboard that I created which contains data from a survey. The issue that I have is that when I click the icon for that dashboard, the dashboard itself does not load, and loads a bunch of code instead, as shown below:
random code, dashboard doesn
The output that I am expecting is for the dashboard to load, like the screenshot below:
dashboard screenshot
For reference, the link to the dashboard can be found here. Everything has been set to shared(public), however, I still receive the error shown in the screenshot above. One thing I noticed from the error screenshot is that in the address bar of my browser, after 'token', there isn't anything written except the =, so I was thinking maybe there is a token issue? Not fully sure. Does anybody have any ideas?
Thanks in advance and let me know if more info is needed or any resources needed are missing.
DerekLaw
Esri Esteemed Contributor
Hi Jeremy,
> For reference, the link to the dashboard can be found here. Everything has been set to shared(public) ...
I just tried to access your Dashboard and it prompts me for a login to access. Please re-check that it and its contents are shared publicly.
Which Gallery template did you use to create your Portfilo app? Category gallery, Layer showcase, or Minimal gallery?
I just tested with the Minimal gallery template and was not able to repro the behavior you describe.
Hope this helps,
