Can we create Map Books from ArcGIS Online?
810
11-08-2022 07:56 AM
HeidiZhang
I am new to ArcGis series. I am using ArcGIS online and did not see the possibility of creating map books as Pro version has.
Is there any alternative solution to create map books online?
Thanks in advance.
DanPatterson
From
Use ArcPy in a notebook—ArcGIS Online Help | Documentation
under Mapping
Arcpy.mp can be used to automate map production and is required to build complete map books because it includes functions to export to, create, and manage PDF documents.
So technically, using a notebook with python in agol, yes, but using Pro would probably be simpler
... sort of retired...
HeidiZhang
Thank you so much. Will look into.
