I'm trying to show related records in a pop-up. According to this blog ( https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/rolling-out-related-records-in-map... ) article, I should be able to do this, but for some reason I do not have the option to "Add Content - Related Records". See screenshot below. Can anyone explain what might be going wrong here??
Here are the details on the webservice I am using. I can view the features, and modify the features fields in the pop-up. Just no access to the related table for some reason.
| ArcGIS REST Services Directory | Login | Get Token |
| Home > services > Works > Valves_Over_Inspections (MapServer) | Help | API Reference |
| JSON | SOAP |
Does anyone know of a public webservice with a relationship in it that is not on AGOL, that I could use to do soem testing with. I'm just not sure where the issue is....the webservice created for me, maybe our firewall, something else??? Who knows.
Have you tried the one I mentioned above? There are other layers in that service with related records:
Thanks @KenBuja .
So just trying the first one in the list, I am still unable to add the "Related Records" (see screenshot below). I am in AGOL. I should be able to, shouldn't I?? Looking at the REST, there appears to be 3 related tables but I don't seem to have an option for any of them.
