Can't view "Related Records" option using a webservice
5658
24
11-02-2023 12:13 PM
BrianBulla
Honored Contributor
I'm trying to show related records in a pop-up.  According to this blog ( https://www.esri.com/arcgis-blog/products/arcgis-online/mapping/rolling-out-related-records-in-map... ) article, I should be able to do this, but for some reason I do not have the option to "Add Content - Related Records".  See screenshot below.  Can anyone explain what might be going wrong here??
Here are the details on the webservice I am using.  I can view the features, and modify the features fields in the pop-up.  Just no access to the related table for some reason.
ArcGIS REST Services DirectoryLogin | Get Token
Home > services > Works > Valves_Over_Inspections (MapServer)Help | API Reference
JSON | SOAP
Works/Valves_Over_Inspections (MapServer)
View In:   ArcGIS JavaScript   ArcGIS Online Map Viewer   ArcGIS Earth   ArcMap   ArcGIS Pro
View Footprint In:   ArcGIS Online Map Viewer
Service Description:
Map Name: Valves Over Inspections
Legend
All Layers and Tables
Dynamic Legend
Dynamic All Layers
Layers:Tables:Description:
Copyright Text:
Spatial Reference: 26917  (26917)
Single Fused Map Cache: false
Initial Extent:
      XMin: 670900.4892873524
      YMin: 4861540.759367962
      XMax: 671264.1504525405
      YMax: 4861797.333926209
Full Extent:
      XMin: 632250.5783000002
      YMin: 4845167.040200001
      XMax: 706521.8962000003
      YMax: 4932435.0529
Units: esriMeters
Supported Image Format Types: PNG32,PNG24,PNG,JPG,DIB,TIFF,EMF,PS,PDF,GIF,SVG,SVGZ,BMP
Document Info:
      Title: Map
      Author:
      Comments:
      Subject:
      Category:
      Keywords:
      AntialiasingMode: Fast
      TextAntialiasingMode: Force
Supports Dynamic Layers: true
MaxRecordCount: 2000
MaxImageHeight: 4096
MaxImageWidth: 4096
Supported Query Formats: JSON, geoJSON, PBF
Supports Query Data Elements: true
Min Scale: 0
Max Scale: 0
Supports Datum Transformation: true
Child Resources:   Info   Dynamic Layer
Supported Operations:   Export Map   Identify   QueryDomains   QueryLegends   Find   Return Updates
BrianBulla
Honored Contributor
Does anyone know of a public webservice with a relationship in it that is not on AGOL, that I could use to do soem testing with.  I'm just not sure where the issue is....the webservice created for me, maybe our firewall, something else???  Who knows.
BrianBulla
Honored Contributor
Thanks @KenBuja .
So just trying the first one in the list, I am still unable to add the "Related Records" (see screenshot below).  I am in AGOL.  I should be able to, shouldn't I??  Looking at the REST, there appears to be 3 related tables but I don't seem to have an option for any of them.
KenBuja
This is an older server, running on 10.91. From what others in the thread have said, that capability isn't available yet on Enterprise servers until 11.2 is released.
BrianBulla
Honored Contributor
Thanks Ken
