Can't edit Hosted Feature Layer Domains in ArcGIS Online
9772
12
08-10-2020 10:16 PM
by Anonymous User
Not applicable
Hi all,
Does anyone know why I cannot edit a hosted feature layers domains in ArcGIS Online?
Noticed there was a difference with the JSON for a Feature service that allows editing and the one I'm having trouble with.
FL I cannot edit
FL I can edit
Found that it may be to do with the highlighted fields in the troublesome Feature Layer here (
following this article here How To: Add coded value domains to a hosted feature service from a REST endpoint
Does anyone know how to enable domain editing on this feature layer?
Cam
Tyja11
@mikaël - what type of issues are you experiencing? I am debating on updating the source definition for a hosted feature layer.
mikaël
@Tyja11 I can't remember, just that I couldn't update the layers and tables in the hosted feature service because of this parameter. Possibly I had forgotten to update the parameters "hasStaticData" and "sourceSchemaChangesAllowed" in one of the joined views (I had like 5 joined views in the hosted feature service). I had to change those regularly when changing layer/table structure and so on (learning as I go).
tikola
by Esri Contributor
This document gives supports instructions to the steps above and in my case it worked well: https://support.esri.com/en-us/knowledge-base/problem-unable-to-edit-the-domain-values-of-a-hosted-f...
