Can't change visible range for tile layer created out of feature layer
2812
06-23-2022 07:00 AM
MaticDi_Batista
I first created a feature layer out of a set of data I have. Then I styled the data (in map view) and created TileLayer out of that feature layer. The issue is, that even if I set the visible layer for the feature layer to "World" I can't set it for TileLayer. When I change it, the TileRange table is just processing indefinitely:
And nothing changes. On the client, tiles are still 404. I have option "Create tile automatically" ticked, so I guess that shouldn't break the system.
Is there anything else I'm missing?
by Anonymous User
Not applicable
Hi there! Thanks for reporting this. I tested this same workflow earlier this morning and could indeed reproduce what you see. But I have since tested again and can no longer repro. We can sometimes see temporary blips like this - do you mind retesting and confirming if you still see the behavior? Thank you!
Sarah
ArcGIS Online Product Advocacy Lead
MaticDi_Batista
TileLayer is still returning 404 for higher ranges. Should I recreate the TileLayer?
by Anonymous User
Not applicable
Bummer; yes let's try recreating. Let me know the results!
MaticDi_Batista
I've tried recreating it, but it's always the same result. Tiles for higher levels are not created.
by Anonymous User
Not applicable
Sorry to hear you are still having trouble! I think at this point, it would be best to contact our Technical Support department for further help. An analyst can help us get to the bottom of what's going on in your environment. Thank you!
