In a web map the Attribute table will show you how many related records there are for each Relationship Class.
Like this
Is there any way I can get\use this number? Any way to use it to symbolize? Sort by?
For example I want to be able to tell the user they only have 2 LPI forms when it should be 3. AKA how can the user get a list of features that were not fully completed.
In Arcade I can do a check using FeatureSetByName but then I again cannot symbolize or filter. Plus the user would have to click show a thousand times in the attribute table. (The word Complete is where I clicked)
All of these expressions are also hidden from Ops Dashboard. They will show in a popup but cannot use for filters or anything like that. If Ops Dashboard cannot use Arcade can it get this Related records number at all?
Any other ideas on how to do a dynamic QC to see if the job is complete based on the number of related records?
I know I can run some analysis but that becomes static in time. Meaning I have to run it on the regular. It also means a download, run, upload. I have tried to run analysis directly from the Feature service using a SearchCursor /JSON - and it works great on FCs but on tables it does not work (should but just doesn't). In this case all the main level relates I am checking are FCs so this may work actually in this case.
Also cannot use the Arcade expression in any of the Analysis tools in AGOL.
thanks a lot
