Can Data Be Downloaded as a File Geodatabase from Hub (Open Data)
628
06-17-2022 09:34 AM
MichaelVolz
Esteemed Contributor
I would like to share data with an outside organization using Hub (Open Data).  I would like the other organization to be able to download the data in file gdb format so that long field names are not truncated and curves are maintained.  I only see download options of CSV, KML, Shapefile, and GeoJSON.
Is it possible to download data in file gdb format from Hub (Open Data)?  If so, is there some configuration change I need to make to allow this type of download format which meets the above business requirements?
