Ca not move down layer in Web Map
1363
12-27-2021 11:21 AM
JoseSanchez
Hello everyone,
I added a new layer to a Web Map that has several layers created from map services, and now when I try to Move Down the layer, I could only move 1 position. It looks like a regular layer can not move through layers that are created from map services.
Please advise
Jose
JayantaPoddar
Are there multiple layers within the same map service that was added to webmap?
Try adding the layers individually (to the webmap) instead of adding the map service.
e.g. Instead of Adding https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer
you could add
https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0
https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/1
https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/2
https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/3
These layer will be added individually, which can then be reordered.
Think Location
Kanin
by Esri Contributor
Hello Jose,
Are you using Map Viewer Classic? Because another solution would be to use the new Map Viewer. The new Map Viewer supports reordering layers regardless of layer type. Please try the new Map Viewer, if possible.
 Map Viewer web map compatibility—ArcGIS Online Help | Documentation
Also, ArcGIS Dashboards support using web maps authored with the new Map Viewer. Dashboards Classic does not. Which dashboard are you using?
Best regards,
Kanin
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
