Bold Text within Arcade Expression
4193
10-07-2022 11:13 AM
MelissaSalich
I have an expression in Arcade and I want to bold only one part of it.
$feature["SPACEID"] + TextFormatting.NewLine + "Wheel Chair Stations: " + $feature.WCHAIRACCESS + TextFormatting.NewLine + "Barrier Free Door: " + $feature.BARRFREEDOOR
How do I bold only SPACEID?
New map viewer, Portal
Tags (1)
RussRoberts
Esri Notable Contributor
I would do 2 different label classes and set the position for the label with the label styling.
RussRoberts
BernSzukalski
Esri Frequent Contributor
Or, an easier way (assuming you're just doing text in a pop-up) might be to use an Arcade element. You have access to all the HTML formatting so making part of your text bold is easy, peasy.
ReydeCastro
How do I use HTML tags within Arcade?
