ArcMap > File > Sign In. I want to sign into a different organization than the one shown in IE 10
2890
07-03-2016 08:47 PM
SteveSedlock
In ArcMap, I go to File > Sign In. The resulting IE 10 window goes to a specific organization's login URL. I want to log into a different organization, but I cannot change the URL (no address bar available, nor am I able to turn it on through any setting or shortcuts).  Just trying to login also does not work.  Below is an image of the IE 10 window with the error.
I am operating in the AWS environment.
Tags (1)
SteveSedlock
I figured it out.
AdrianWelsh
MVP Honored Contributor
Hi Steve,
Can you explain what you did to make this work? Was there a different button on the login screen for changing organizations or sign out button or so?
SteveSedlock
Adrian,
Do you know how to access ArcGIS Administrator?
JonathanQuinn
Esri Notable Contributor
You should use the ArcGIS Administrator to change the portal that Desktop is connecting to.
AdrianWelsh
So, I take it that using the ArcGIS Administrator is the answer to this question...
