ArcGIS Pro pop-ups stopped working on multiple layers
4225
8
05-17-2023 01:31 PM
lance0
My pop ups in ArcGIS Pro 3.1.1 have stopped working on multiple layers. 'Visible layers' is selected in the Explore Tool settings. Instead of getting a pop up for each visible layer I now only get one pop up. It's like the settings are stuck on 'Topmost layer'.
Has anyone else experienced this?
AnnKiselaLEGIS
I am having the same issue.  You're right, like it's stuck on 'Topmost Layer'.
MackenzeOriger
I am also having this problem. It's incredibly annoying, I have to wonder if it has something to do with being on Windows 11.
AnnKiselaLEGIS
Esri showed me that my layers were hidden because I needed to expand the stacked elements. In the picture, hovering over the vertical line says "Split into two vertically stacked elements".  I hope this solves your issue too.
MackenzeOriger
Thank you, that solved it! I'm glad it was just a matter of me overlooking a well-hidden UI element and not a bug.
DanielHoffman73
Thank you....this was driving me nuts!!!
AZendel
Thanks for explaining this. It was also annoying me. ESRI, I suggest that you make it more obvious that there's a collapsed pane that can be expanded.
bkaplan_WHO
This was driving me nuts too.  In Pro 3.4, the bar showed up in the upper right hand corner when I hovered or clicked on it.  Its shown circled in red below.  Once I changed it though, I do not get the bar back and cannot revert to the previous format otherwise I would have showed you.
In ArcMap perhaps, I thought the number in the bottom left indicated how many popups there were?  Am I hallucinating and wasn't that a good thing?
MarhensaAditya_Hadi
@bkaplan_WHO wrote:
This was driving me nuts too.  In Pro 3.4, ....
There's a new way, and this kinda weird and not intuituve at all. I learned this today that if it's multiple features, we need to use Ctrl + Drag a little box, to identify multiple features.
drag a box while pressing the Ctrl key to identify multiple features.
Pop-ups—ArcGIS Pro | Documentation
