ArcGIS Online: “web map” that is shared as “everyone” still requires logins when open with “map viewer”,
3028
8
03-07-2020 12:58 PM
JamalNUMAN
Legendary Contributor
Despite the fact that the “web map” that is shared as “everyone”, it still requires logins when open with “map viewer”.
What could be the issue here?
Jamal Numan
Katie_Clark
MVP Regular Contributor
Ah, yes you are right. I only tried the short link before. When I typed in the long URL shown in your screenshot, it asked me to login.
However, when following the short link from your screenshot (http://arcg.is/0COfnf), the browser populates with the following URL:
https://www.arcgis.com/home/webmap/viewer.html?webmap=725bf1a6ec594a619c2268444f56de62
Notice how this is different from the long URL in your other screenshot, which is:
http://k241.maps.arcgis.com/home/webmap/viewer/html?webmap=725bf1a6ec594a619c2268444f56de62
The link that asks for a login starts with "k241.maps" so it seems like it is wanting to link directly to within your organization (I think that's what's going on, anyway). The link that works just starts with "arcgis.com..."
As a side note: I highly recommend sharing your links directly through text like I just did, rather than through screenshots. (that relates to your other post regarding sharing web maps)
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
It's likely that there is a layer within the map that isn't shared with Everyone. Can you confirm if that is the case?
Best,
Katie
JamalNUMAN
The web map includes only one layer and it is shared as “everyone”.
I observed that if the short link is used to access the web map, then no logins are required. But if the long like is used, then logins are required!
Is this by design?
Jamal Numan
Katie_Clark
Following the URL in your screenshot, I was able to view the map without needing to sign in.
I recommend trying to open the map in an Incognito Window in Chrome (or similar in a different browser) to see if the problem persists.
Best,
Katie
JamalNUMAN
Precisely. This is what I have done. The ArcGIS Online is open with chrome. Both the long link and short link are open with Microsoft Edge. The long link requires logins but the short link doesn’t
Are you able to replicate the issue at your environment?
Jamal Numan
Katie_Clark
Best,
Katie
JamalNUMAN
Thank you for sharing the input. This is very useful
Jamal Numan
Katie_Clark
Glad it helped!
Best,
Katie
abdullahqasrawi
Dear Jamal
Try to open your map directly from the link that appears in ArcGIS Pro, Screenshot below.
