ArcGIS Online is converting my table's text field to 'integer' data type.
8979
17
10-24-2019 11:46 PM
PersefoniKapotas
I am trying to add a table to my content as a hosted layer.  It is an excel table that has a column with numeric values stored as text.  I did check to make sure that it was a text/string field.  AGOL automatically converts the field to 'integer' and I can't find a way to convert it back to string, which I have to do because I want to join the table to a layer using this field.  I tried bringing it into arcgis pro first, and arcgis pro recognized it as a string field so I didn't go any further with that idea.  I ended up adding a new string field in agol, and copying over the data (i had to do some calculations to add a 0 in front, etc.). But i'm wondering if there is an easier/more straightforward way.
Why doesn't AGOL respect the data types from the original table?
VanessaGoold
Hi Peter and Sam,
I've received further assistance from ESRI Support and here is the upshot:
1. To preserve plain text formatting from the Google Sheet, you need to insert an empty column, pre-format that as plain text (Format > Number > Plain Text). Then copy your data and use Paste Special...Paste Values Only into your pre-formatted column. Here's a link to explain:  https://www.howtogeek.com/470254/how-to-enter-zero-before-a-number-in-google-sheets/#:~:text=If%20yo... follow the workflow under the "Apply Plain Text Formatting" section.
2. In ArcGIS Online, a .csv published from the web will only refresh if it has location data (e.g., latitude and longitude coordinates). If it's not a spatial table, it won't refresh. So you have to add latitude and longitude to your Google Sheet. In my case, I am using USA County data. Sam, you might be able to find a ready-made table with ZIP Code coordinates out there if you need your data to refresh; otherwise ignore the rest of this. This might be the long way around, but here's how I did it:  I was able to extract centroid points from US Tiger Line County polygon data in ArcGIS Pro (desktop version) following the instructions here: https://support.esri.com/en/technical-article/000009381. This table had latitude, longitude, and FIPS field data in it. I then exported the table to Excel format using the ArcGIS Desktop Table to Excel tool. I imported the Excel data into a new tab on my Google Sheet. Then in my County data tab, I added two new columns, Latitude and Longitude. I used the function:
=Index([insert Latitude column from Excel tab], MATCH([insert first FIPS code cell to look up],[insert FIPS array from the Excel data tab],0))
This returns the Latitude value for the county sharing the same FIPS code in the second tab. Copy down to fill in all values. Then do a whole column Copy > Paste Special > Values Only to get the number value in there rather than the formula.
Repeat for the Longitude Column.
Next I refreshed the Google Sheet's File > Publish to Web > CSV link and re-imported into my AGOL map using the latitude and longitude coordinates. I'm still working on the join, but at least now I have live, refreshed data imported with my FIPS field coming in correctly as text/string.
SamSimpson
Ah, I hadn't seen this additional reply.
Is this specifically steps for adding a 'published .csv' to AGOL? I attempted the first step with an Google Sheet and was still presented with all integers.
SamSimpson
Hi Peter,
I believe those are the issues though I look to @VanessaGoold on the second one, I haven't attempted that route. It seems like having the ability to specify a fields data type with Google Sheets would solve both of the problems?
I shared some similar dummy data with you via Google Sheets. Thank you for your help!
Sam
SamSimpson
Hi Vanessa,
I haven't attempted any more tries with this for the moment but I did look at the link you sent - as the blog post was created in 2012 I wonder if this was pre- the ability to add Sheets via a cloud connection? It seems Esri adding a mapping ability to field data types would solve our problems!
I will let you know if anything changes on my end, thank you for suggestions and help!
Samantha
by Anonymous User
Not applicable
Hi Samantha and Vanessa,
Thanks for the update on this. I agree that it would be a valid enhancement request for field mapping/specifying data type when adding a Google Sheet to ArcGIS Online. @SamSimpson let me know your customer # and I can get a case going for you to log this.
As for the update without Lat/Lon values, this one is a bit trickier; without Lat/Lon values a geocode request would need to occur to plot the points which could incur unknown amounts of credits depending on the number of records added. @VanessaGoold I looked at your case and it seems the credit usage was from the join in ArcGIS Online; adding points with Lat/Lon does not use credits.
-Peter
JohannaS
Hi!
I always upload as CSV and have never seen the option to change field type on upload to AGOL. I am having the same issue with text being changed to number in a CSV file that I'm uploading and I can't do the join that I need to do. I can look up how to change or create a new field, but is there any easier way to have it stay the way it is in my CSV file when I upload it?
JohannaS
Oh, I see what I was doing! In case anyone else is doing the same thing as me, you have to upload it from my content as a hosted layer (not from a map) https://support.esri.com/en/technical-article/000026756.
souzadias
Hi folks,
I'm having the same issue of AGOL reading text as numeric but also numeric as text. Particularly, if a column stores numeric values but has empty cells (null or empty), AGOL will read it as a string. Of course, I can upload as CSV and edit the field type, one by one, by I have a file with over 100 columns. It's just not practical to edit the field type every time I need to re-upload my file. There needs to be a more predictable way to structure an incoming data file so that they are correctly read by AGOL. Alternatively, a way to assign field type from the original file and avoid fiddling during the upload.
