How do you allow other users to edit your web mapping applications in ArcGIS online?
18314
6
03-30-2020 08:50 AM
BenJackson
Myself and my team are working on an application within ArcGIS online, which we created in the web app builder. We can all access the app as we are part of the same user group, but only the creator of the app appears to be able to edit it, and we cannot find any settings that will allow the rest of us to edit as well. We are all creator level users. Is there a way of enabling the whole team to be able to edit the application?
Katie_Clark
MVP Regular Contributor
Ben Jackson‌, you can create a group with shared editing capabilities and then share the web map and application with that group. (and make sure the people who need edit access are members of that group)
Another option would be to change your user types to Administrator level if that's possible for you. Then you can edit all content, regardless of who the owner is.
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
RichardRogers1
This is exactly what I want to do (allow other group members to edit an existing webapp that I "own"; however, the option radio buttons that you describe are not available to me when I create a new group.  Is it possible that this due to my "user type"(creator) or "role" (publisher)?
There is an option to allow others to contribute content, but this is not the same as editing.  This seems like such a rudimentary function of group sharing that should be available to folks who are developing content.
JakeSkinner
Esri Esteemed Contributor
Hi Ben,
When you create the Group, under the setting What items in the group can its members update?, check on the option All items (group membership is limited to the organization).
Create groups—ArcGIS Online Help | Documentation
Egge-Jan_Pollé
Hi Ben Jackson‌,
The trick here is to change ownership, as only the owner can modify or edit a Web Mapping Application.
From your description of their rights, it looks to me like all your team members have the power to take the ownership of the app themselves. I.e. it is not necessary for the owner to hand over ownership; a user with sufficient rights can take it anyway...
Does this solve your issue?
Egge-Jan
BenJackson
Hi all,
Thanks for your replies. It seems the issue is that none of us have sufficient permissions to create a group with update capabilities. I'll have to ask an Administrator to do that for me. Once that's done, I'll see if it works at the point, and if so I'll mark this as answered.
Scoth
I'm wondering if a Facilitator role would be sufficient, or if it has to be an Administrator role. The documentation doesn't specify for this use case.
