ArcGIS Online: Inviting members ends up with “insufficient user types” error,
1093
03-07-2020 12:35 PM
JamalNUMAN
Legendary Contributor
Despite the fact that only one user is created (as shown in the screenshot below), inviting members ends up with “insufficient user types” error.
What could be the issue here?
Jamal Numan
Katie_Clark
MVP Alum
It seems like you're confusing "User Type" vs. "Role". In the screenshot you posted, you're still trying to assign the user a User Type of "GIS Professional Advanced" with a Role of Viewer. This won't work because you only have one available. Changing the User Type to viewer should fix your issue.
For reference, here is a link to Esri's page on User Types, Roles, and Privileges:
User types, roles, and privileges—ArcGIS Online Help | Documentation
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
MVP Alum
It seems to me like it's just an issue of how many licenses you've purchased for your organization...does it say that you have any remaining?
You can check this under the Licenses > User Types tab of the "Organization" section in ArcGIS Online (assuming you're an administrator)
Best,
Katie
JamalNUMAN
It says that there are 3 users available as “viewer”, nevertheless, the error message appears.
Jamal Numan
Katie_Clark
MVP Alum
Best,
Katie
JamalNUMAN
Many thanks Katherine for the help. It works with me
Jamal Numan
