ArcGIS Online Arcade time based expression
3053
06-14-2021 10:46 AM
OliverSandoval
Hello, I am new to arcade and am looking for any advice in the direction I should go for creating a script for an feature service in a web map. I want to be able to change the symbology of the layer based upon what week it is. So the script would ideally switch from Week A to Week B every 7 days and the current week's polygon borders would be highlighted in red. Any advice would be greatly appreciated!
DavidPike
MVP Notable Contributor
I'd possibly use the ISOWeek() Aracade method to check the numerical ISO 8601 week (week starts on Monday) of your date field value, and compare it against Now().  And have this as a symbology expression.  Something like:
//does not account for dates in the future
if ( ISOWeek($feature.yourDateField) == ISOWeek(Now()) ) {
  return 'ThisWeek'
else {
  return 'NotThisWeek'
DavidPike
  return 'ThisWeek'
else {
GIS_Fox
Hi @OliverSandoval ,
I've used a script almost identical to @DavidPike 's in his screenshot above. I used the documentation found here for reference if it helps, too: https://developers.arcgis.com/arcade/function-reference/date_functions/
Cheers 🙂
Jansen Lyons - Records and GIS Section - Public Works - City of Rio Rancho, NM
OliverSandoval
Hi @GIS_Fox thank you very much! Ill most definitely be using that! 😊!
OliverSandoval
Awesome thank you so much David for your response! Ill try it out!
