ArcGis Map Access problem
16703
19
09-05-2023 06:27 AM
nevcivanokumuş
Hello,
I was previously downloading maps using QGIS from an ArcGIS server. However, now when I'm trying to access the server, I'm receiving an error that says "Arcgis: Access denied: Forbidden."
The server I'm trying to access the map from has the following URL: https://services.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer/tile/{z}/{y}/{x}
I used to download images in PNG format from there. However, even when I try to access the page by manually entering z, y, and x coordinates in my web browser, I can't access the page anymore. What could be the reason for this issue, and how can I resolve it?
Thank you for your assistance.
Faiez
Hi!
1. Remove temp files
2. Use this URL link :
3. Follow the instruction in video
(view in My Videos)
Good luck
ecemmanav0
Hello Faiez,
I am struggling with the same issue too. I tried all of the solutions. I always get this error when I click on the link. So, we are facing server blockage.Screenshot from 2023-09-11 15-39-32.png
Faiez
This option works 100 %, via XYZ connection: Try to establish a connection like the one that you have made for ArcGIS REST Server. This time make a connection by XYZ connection.
http://www.google.cn/maps/vt?lyrs=s@189&gl=cn&x={x}&y={y}&z={z}
If you succeed, your screen should looks like this
nevcivanokumuş
hello faiez,
this map is Google Maps. Its already works. But we want to work arcgis maps. I tried every method of your demonstration but it didn't work.
nevcivanokumuş
Merhaba ecem, malesef bende de aynı sorun var. Uzun süredir herhangi bir indirme yapamıyorum. Hiçbir çözüm bulamadım.
ecemmanav0
Ne kadar süredir aynı sorunu yaşıyorsun acaba?
nevcivanokumuş
2 haftadan fazla süredir devam ediyor
ecemmanav1
Eğer bir çözüm bulursan burada paylaşabilir misin acaba?
ecemmanav0
Tekrardan merhaba Nevcivan,
Herhangi bir çözüm bulabildin mi bu sorun için?
