ArcGIS ESRI app crashing when I change symbols
5320
21
11-30-2012 07:16 AM
ChandraMiller
I am having problems with the ESRI app.  My map is crashing the app.  I created a map to just test out what the exact problem is.  I have four layers added.  The last layer was USGS Gages.  The USGS Gages file is a point file and when I import it the symbols are red dots.  Everything works great as long as I leave the USGS Gages symbols as the default red dot.  When I change it to a purple dot, the app crashes when I open my map.  Why is changing a symbol color causing the app to crash?  Here is my map (with default symbols so it won't crash)- http://bit.ly/SznF5Z.
Chandra
CoreyPackard
This is still a problem. Any word on an actual fix?
Thank you!
DrewSutton1
This has been an on-going issue for the ArcGIS app on iPad for a long time now.  I have suffering from all of the same issues the above users have outlined.  Changing symbols crashes the map.  If you change anything else in relation to the layer (pop-ups for example) the layer simply vanishes from the map display.  ESRI really need to address these issues.
