Arcgis.com web mapping applications and widgets
1442
10-13-2011 04:21 AM
OlaSvensson1
Hello,
I am wondering if it is possible to extend the web mapping applications created with the Arcgis.com Map viewer with e.g. query widghets (such as http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Query_widget/01m30000000t000000/ or something similar written in javascript)?
I am aware that it would be better, and probably easier, to just create a WMA from scratch using Flex/Javascript and link it to our GIS server, however my work will not have access to ArcGIS Server for about 6 months. The reason I'm asking is that I would like to add some query possibilities to an incredibly simple WMA; I want the users to be able to search and select polygons based on for instance area (or 2-3 other attributes).
MikeMinami
Esri Notable Contributor
Yes, it is possible... Check out the JavaScript API. Here's a link to the samples section.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
Good luck,
Mike
OlaSvensson1
Good luck,
Mike
Aha! Thank you oh so much, you've saved me a lot of headache.
