ArcGIS Blog RSS Feed Incompatible
4119
31
11-25-2024 02:17 PM
OpenDataCLE
Hello!
We like to keep up with ArcGIS Blogs here using the RSS feed. In fact, it's the best indicator of major product updates and we like to keep informed both for new features but to be prepared for changes.
For months I've been using a Microsoft Power Automate flow, which will ping the RSS feed: https://www.esri.com/arcgis-blog/feed/?post_type=blog
For the last month it is failing! Did Esri change something? Encoding of characters is extremely important and it looks like something isn't formatted right? Can Esri team please look into this? Your RSS is virtually down for us until this encoding issues is fixed. Again, this worked perfectly fine for the last few months.
Failed to read requested Feed information. Details: 'og' is an undeclared prefix. Line 42, position 4.
clientRequestId: 76c46781-775f-46c8-bd50-418f6902e829
Here is the standard RSS connector that works with every well-defined RSS and is used by millions of people. https://learn.microsoft.com/en-us/connectors/rss/
SarahNoakes1
It looks like it's back this morning.
AnthonyJonesRSK
I'm still getting an issue with this, "Failed to read requested Feed information. Details: 'og' is an undeclared prefix. Line 69, position 4.", when accessing the feed in Power Automate. I also tried accessing the feed through a Chrome add-in and when trying to subscribe to the feed it just comes up with a parsing error. Can someone from Esri confirm if this is still being investigated please? Thanks
AnthonyJonesRSK
Actually mine looks to have kicked in again on the weekend so all sorted now. Thanks
SimiBasu
Esri Community Manager
Thank you for the update @AnthonyJonesRSK . We restarted the community so that might have fixed the issue.
Lloan
by Esri Contributor
Please let me know if anyone has further issues with this. We deployed a fix 12/13 - thank you for your patience.
SarahNoakes1
Thank you @Lloan  & @SimiBasu - it's such a useful resource, so it's great to have it back.
PierreloupDucroix
MVP Regular Contributor
It's back in my favorite RSS app !
Thanks
CEO of MAGIS
AnthonyJonesRSK
Hi @SimiBasu,
Do you know if the recent AWS issue has caused any problems with the blog RSS? My Power Automate flow hasn't run since last Friday and upon checking it I'm getting this error "The underlying RSS server forbids incoming requests". Any info on this would be much appreciated.
Thanks, Anthony
SimiBasu
Hi @AnthonyJones , thank you for reaching out.  I am working with the support team to find out more. Meanwhile, could you please provide the specific RSS feed URL you are having issues with?
AnthonyJonesRSK
@SimiBasu, thanks for your response. The feed URL is https://www.esri.com/arcgis-blog/feed/?post_type=blog. Is that still the correct one? Thanks
